Posted by sony224422 on January 27, 2014 at 09:14:42 from (12.111.44.98):
I cleaned my carb and checked my float and got it to stop leaking. I also replaced the spring in my governor. While in there I adjusted the carb to governor linkage that was pretty out of whack. I swapped engines from a bad one to a new one and the governor was swapped too. So the adjustments make sense. The adjustments made a big difference along with the carb cleaning but now my question is, when starting off in 5th gear it sounds like it's about to stall, but won't and will eventually pick up and go. Once going it seems ok until I start going up hill. It seems like it bogs down a lot and really works to try to keep going and I lose speed. I'm not sure how normal this is. The uphill is a slight incline but maybe 1/2 mile long. I also noticed sometimes it seems to surge while driving on flat ground but I can't predict when it will do it or if it will do it. Is this a governor issue or a carb issue? I think my carb is adjusted pretty well but I've also never heard a well running tractor. It seems to idle well, at a very slow speed and cleanly revs to full throttle with little black smoke. I also have electronic ignition.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
