Posted by sony224422 on January 28, 2014 at 07:06:00 from (12.111.44.98):
In Reply to: Farmall h governor posted by D Slater on January 28, 2014 at 04:34:00:
I'm confused as to why when I set tdc and pull the distributor and align it so the rotor is pointing at the number one wire and assemble it this way, after it runs and I set tdc the rotor is again pointing the way it is in the picture? Tractor starts and runs and is not back firing, I know an engine out of time will not run
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
