Posted by D Slater on January 28, 2014 at 04:34:00 from (184.14.177.12):
In Reply to: Re: Farmall h governor posted by Janicholson on January 27, 2014 at 11:58:01:
Jim unless the H pulley was changed or marked later there will only be double marks close together or one mark at TDC. With double marks the first to pointer on # 1 compression stroke turning crankshaft normal rotation is TDC. If the pulley also has a mark to locate the pilot grease fitting in the flywheel it will probably have the double marks to ID from the grease locater.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
