Posted by sony224422 on January 27, 2014 at 11:37:22 from (12.111.44.98):
In Reply to: Farmall h governor posted by Janicholson on January 27, 2014 at 09:47:00:
I'm pretty sure I am timed correctly. What I did to time was rotate the engine to the first mark on the pulley and then I made sure the rotor was pointed to number 1 on the cap. It starts fairly easily, usually with one or 2 revolutions. The carb adjustment I'm not sure if I'm good on. I started at 1.5 for idle and 3 for main. I am going to try and fiddle some more. It's 3 turns out from it being finger tight correct?
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
