Posted by sony224422 on January 27, 2014 at 14:34:46 from (198.228.200.173):
In Reply to: Farmall h governor posted by David G on January 27, 2014 at 14:19:36:
I think I am confused by timing.. I set tdc and took the distributor off turned the shaft until the rotor pointed to 1 and put it back on. Wouldn't start. So I took the cap off again and it was pointing 180 from 1 on tdc. Put it back how it was and it fired up.
Timing from ear might be what I have to do along with playing with carb settings.
It should be able to take off in 5th gear shouldn't it?
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
