Posted by Janicholson on January 27, 2014 at 09:47:00 from (74.60.94.18):
In Reply to: Farmall h governor posted by sony224422 on January 27, 2014 at 09:14:42:
Try opening the load screw on the carb one half turn at a time. it sounds like it is lean. If the engine does get to full RPM, the governor is probably not the issue. The mixture and Ignition timing are both critical to power loss.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
