Posted by Janicholson on January 27, 2014 at 14:44:37 from (74.60.94.18):
In Reply to: Re: Farmall h governor posted by sony224422 on January 27, 2014 at 13:53:09:
More or less. The trigger timing (Spark moment) must be specifically located within a degree or two. If the initial timing is wrong it will not be correct at any engine speed. See if you can get a copy of the timing instructions for the electronic unit. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
