i would drop the oil pan and see what sleeve is leaking. if you are getting coolant in the cylinder, i would suspect either a cracked cylinder, bad head gasket or cracked head. if the o ring is leaking, it would generally leak into the oil pan, not fill the cylinder. when you pulled the spark plugs, you should know what cylinder had anti freeze in it. been a while since i overhauled that engine, iif i remember, the head holds the top of the sleeve in, and the head gasket helps to seal the top of the sleeve.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
