Right after I got the tractor and drained the crankcase, I pulled the pan. Nice and clean. Then I filled the radiator with water and layed under the exposed crankcase to watch for water/drip. Nothing. But someone said it would probably have needed pressure to cause a drip. I drained everything and gave up on that idea.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
