Re: Farmall M clutch adjustment remaining?
Posted by georgeky on July 05, 2007 at 11:47:49 from (152.163.100.197):
In Reply to: Farmall M clutch adjustment remaining? posted by chadd on July 05, 2007 at 11:09:18:
With free play adjusted correctly on the pedal, it will not effect the throwout bearing. You lengthen opr shorten the rod to do this' whichever the case may be.. This only moves the pedal and nothing else. If you are having slippage problems you do need a clutch, pressure plate and throwout bearing, and maybe a rear main seal in the engine. Often times oil seeps from the engine and gets onto the clutch and or flywheel thus causing clutch slippage. Again the pedal is all you are adjusting for disc wear compensation. Put one of the 4 button clutches, which is the heavy duty clutch and it will not slip.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
