Re: Farmall M clutch adjustment remaining?
Posted by georgeky on July 05, 2007 at 12:53:22 from (205.188.116.73):
In Reply to: Re: Farmall M clutch adjustment remaining? posted by chadd on July 05, 2007 at 12:32:21:
Chadd, the free play is measured from the platform of tractor to the clutch pedal. The spring is what returns it to the same position all the time. This rod only adjust the amount of free travel in the pedal distance from the platform. The proper free travel distance from pedal to platform is 1 and 1/8th of an inch. This is determined by pushing the pedal in until it meets resistance. Then measure from pedal to platform and adjust accordingly to 1 and 1/8. It does nothing to the clutch itself. Again the rod doesn't adjust anything except the pedal travel. Once the clutch starts slipping there is nothing you can do to remedy it except replacing it or the pressure plate or both. If you adjust the rod to keep pressure on the throwout bearing it will cause problems such as disc and throwout bearing wear.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
