Re: Farmall M clutch adjustment remaining?
Posted by chadd on July 05, 2007 at 19:27:52 from (4.188.128.243):
In Reply to: Re: Farmall M clutch adjustment remaining? posted by georgeky on July 05, 2007 at 12:53:22:
Yes, the rod does adjust the pedal free travel, however, am I correct in saying that the clutch will not work properly if the clutch pedal is no longer able to compensate for the thinning of the friction disc? Correct me if I am wrong, but isn't the purpose of adjusting the linkage to prevent the throw-out bearing from touching the fingers with the clutch pedal in the rest position, which could lead to slippage? I am just trying to determine if I have a whole clutch worth of adjustment left or almost nothing at all. I have about 4 or 5 of the rod threads inside the clevis and about 20 or 25 in between the two clevis ends. The tractor originally had excessive free-play which I remedied by lengthening the rod (leaving me with 4 turns in the clevis). As the clutch wears, the free play should decrease right? So that should mean that I should shorten the clutch linkage to account for wear, which would mean that I have a ton of clutch left, correct? That is what I am concerned with. Thank you for your post, I appreciate your time and help.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
