Posted by old on May 28, 2012 at 19:29:25 from (209.86.226.27):
In Reply to: Carb trouble posted by NationalHarvester460Hi on May 28, 2012 at 18:26:43:
Well to start with you have flooded it an will need to clean the plugs since they will be gas fouled. Next your float is sticking or bad or the needle is not seating as it should because of dirt/rust or other such thing
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
