Posted by Janicholson on May 28, 2012 at 20:49:23 from (67.72.98.45):
In Reply to: Re: Carb trouble posted by NationalHarvester460hi on May 28, 2012 at 19:57:52:
That carb solenoid opens when the ignition is on and shuts when it is turned off. A solid click should be heard when it works. (you need to be near it to hear it), be careful with it in neutral. Taking it out should find gasoline coming from the hole. It is not adjustable. If the fuel is old, drain it and put in fresh. Old fuel often will not fire well. Put it in a mix with other fuel and use it, but put fresh in the tractor. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
