Posted by old on May 28, 2012 at 20:05:35 from (209.86.226.27):
In Reply to: Re: Carb trouble posted by NationalHarvester460hi on May 28, 2012 at 19:57:52:
I can not say about a carb with that solenoid since I have not messed with ones with them. Another thing to check is pull the air cleaner tube off and hold your hand over the carb and crank the engine over. You should fell a good bit of suction and if you do not then you may have a manifold gasket problem or low compression
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
