Posted by farmallboy15 on May 18, 2011 at 12:33:15 from (99.197.224.57):
the tractor is loose. it was running great a month ago. ever since when i try to engage the starter the is a small click but that is it. the battery is good. the ground is good. i have tried two different starters and i also put a new switch on the starter. Any ideas on what to check? the battery cable maybe?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
