Do you know 100% sure that the engine will turn over by hand??? If you do not try that first. If you can not turn it by hand pull the plugs and make sure you do not have fuel or water of something else hyd locking it. I'm guessing this is one of the older ones with the pull rod and switch on the starter. If you can turn it over by hand then double check every battery cable connection. Also you say you have tried 2 different starters do you use the same switch on both or do they have there own.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
