You should make sure the engine isn't stuck. Use your hand crank to turn over the engine. I would clean all the battery connections until they're shiny and tight and that includes where your battery is grounded. If the cables are cracked I would install 00 new cables. You should be able to start the engine using the hand crank. Make sure its not in gear. Hal
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
