Several points to make: The big coiled flat wound spring should be the return spring for the drive. This spring is pretty heavy, and connected with two bolts into the drive collars. The little spring is not a return spring. No driving force is put through the spring, the drive force is only in the spiral grooves. The little spring is a noise reducer, keeping a little tension on the pinion gear when retracted.
Farmalls in the Letter series, and X00- X50 number series. never used a starter with a solenoid engagement. The X00-X50 series used a starter relay, but it did not pull or push linkage to make the drive move on its shaft.
The clutch type starter drive is way different, it uses a ratchet style one way clutch in the moving part of the drive. Ebay item # 150502997216 is an example of what they look like. They solve many issues particularly jamming. they also have a little spring, but it works.
It operates similar to the type 1, but the internal one way clutch allows the tractor to overrun the drive.
The worn drive on yours is binding at the flywheel and has gotten all the value out of it.(opinion) don't mess with it it is toast. Jim.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
