The one I have is neither the same size, nor of the same Farmall type. So the comparison would not be valuable. Inertia (Bendix style) drives have been used on everything from aircraft to boat motors. A simple way to solve the controversy is to look at (and hold in your hand) the drive at NAPA, or other store. If the sleeve with spiral grooves is attached to the hub with the long bolt, it is as I am convinced it is. If it is free to turn with the pinion I just can't understand what makes the pinion spin out on a spiral that can spin with it. I think almost every part of your drive is grenaded. The investigation is always worth the effort. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
