Posted by WonderingAl on October 31, 2007 at 01:20:52 from (66.32.138.223):
I"ve got a 1949 Farmall M that needs some major engine work, knocking noise...sounds like a WWII tank moving across an open field..."clank-clank-clank". I"ve also been told it would run a professional mechanic around 3000.00 to fix. I have another Farmall M 1947 that runs fine but am thinking about parting it out. First question, could a person swap out the engines between the two and have no problems? Is the engine swapping a difficult endeavor that would require a mechanic or is it a matter of watching the sequence of removing bolts and hoses and being able to reverse the process back? The "clanking" noise is the result of LOW-LOW oil for some time and tractor use. Could the crank shaft be warped? Rods or rod bent? Piston warp? The mechanic talked about a highly probable end result of throwing a rod(s). Or is it a matter of getting an OVERHAUL kit for the M engine....and the knocking is gone? How would someone check...properly diagnose this engine problem? Hope someone out there has the answers. Thanks
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
