Re: 756 vs 826
Posted by Owen Aaland on September 11, 2007 at 22:54:36 from (65.161.86.86):
In Reply to: Re: 756 vs 826 posted by chuck46 on September 11, 2007 at 20:34:21:
Both engines were built in Germany at the same factory.
The 826 has a larger radiator that make the tractor about 2 inches taller than a 756 with the same size tires.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
