Posted by chuck46 on September 11, 2007 at 20:34:21 from (64.136.27.229):
In Reply to: 756 vs 826 posted by taw on September 11, 2007 at 19:24:56:
Hi, They are vertualy the same except the 826 has a longer stroke, increasing the engine from 310 cubes to 358. The 756 will have 75-80 HP, the 826 will be in the low 90's. The 756 has a Duetz built engine assembled in the USA, so it has all SAE bolts and measurements, the 826 engine was assembled in Germany so it has metric. I have a 756 with 9600 hrs. very happy with it, have always heard good things about any 826 around here. Chuck
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
