Re: Rebuilt Carb on 300 U Leaking Gas
Posted by Ron Smith on April 01, 2005 at 14:55:18 from (152.163.101.13):
In Reply to: Re: Rebuilt Carb on 300 U Leaking Gas posted by little john on April 01, 2005 at 09:07:09:
Got it running finally. I think the float was just rubbing/stuck on the side of the bowl. I tapped on the sides of it and it seemed to come loose. It will run at low idle like a champ, extremly smooth, which is great. When I advance the throttle though, it wants to cut out all together. I tried adjusting it several different ways w/the fuel mixture screw and the bowl adjustment. It still does it though. Could this be the linkage to the carb from the throttle? Maybe it isn't quite right. Could it be from the fuel level in the float being too low? It doesn't leak gas anymore, but I can't get it to throttle up/power up. I can adjust the idle speed screw on the side up very high and it runs great, just can't advance the throttle or it kills it. Went in a circle in the pasture on idle. It seems like it takes a lot of choking to get it started. A shot of starter fluid will get it going quickly, but other times, after it dies, it just doesn't want to start on its own.
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
