Re: Rebuilt Carb on 300 U Leaking Gas
Posted by Ron Smith on April 01, 2005 at 19:51:24 from (152.163.101.13):
In Reply to: Re: Rebuilt Carb on 300 U Leaking Gas posted by PAULIH300 on April 01, 2005 at 15:53:53:
Yes, I aligned it and before bolting up the carb, I moved the throttle handle and watched the valve open and close. So, I would think that the alignment is correct as it seems like there is only one way it could go together. The throttle tang fits in the little opening on the carb shaft. It either goes in or it doesn"t. I may have rotated the shaft coming from the governor drive, but it doesn"t seem like that could make a difference. Maybe the float isn"t working right or I have it set too low. I guess I"ll drop the bowl and take a look at it tomorrow. I"ll try bending it a bit to get a little more depth in there. That"s about the only thing there is to adjust. It will kind of throttle up, but won"t go past a certain point or it will die. It won"t move the tractor on the higher throttle. When it has some load, it cuts out.
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
