Farmall M clutch not disengaging
Posted by JIM on February 02, 2003 at 02:45:00 from (67.250.198.124):
Posted before and posts indicated the reason my clutch would not disengage was probably the pilot bearing. Well, new pilot bearing, throw out bearing,clutch pressure plate and disk from IH. Guess what, still does not disengage. Just grinds gears. Pedal travel from deck about 1 inch. Throw out bearing cradle does not seem worn. Checked flywheel 1.406 inches from disk surface to where the pressure plate bolts to the flywheel. Can not figure out what the problem is. This is a late 1952 M with disk brakes with a 248 M engine. With tractor split, the throw out bearing slides just so far and then stops. Will not slide off the carrier like a newer Farmall will. Has anyone had experience with such a problem? Thank you in advance. Thought I would have my tractor back together and running this weekend. Frustration-Frustration Jim (563)583-3716
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
