Posted by Frontline1 on February 19, 2015 at 16:58:35 from (209.181.34.70):
I'm looking at a broke-down 1086, it's a late '80 by the sn. Right now, it starts, runs, and will move forward/back, but no hydraulics (remotes, 3pt, or loader) or PTO. The PTO lever won't stay engaged, if it's a hydraulic engagement (assuming it is), that would make sense with no hydraulics. Didn't try the TA, as the wheels are turned tight left and the loader is down (run off the rear remotes). For Sale, CHEAP.
So my question - knee jerk, I'd say it is the splines on the hollow-shaft. But, no noticeable noise from the clutch area - is there anything else it can be? Does this tractor have the dual pumps like the older ones? I'm not familiar at all with 86's. This one is high-houred at 9350, but all I really need is a general-use tractor, augers and grain vacs, maybe a baler, etc.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
