Re: Stuck In Reverse
Posted by old on July 06, 2014 at 14:16:40 from (209.86.226.27):
In Reply to: Stuck In Reverse posted by famousfather on July 06, 2014 at 13:53:20:
Try moving the shifter into the reverse position and then move the TA and then try to take it out of reverse and see if it does come out
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
