Posted by 56 Fan 400 on July 07, 2014 at 08:53:01 from (75.228.158.247):
In Reply to: Stuck In Reverse posted by old on July 06, 2014 at 20:30:15:
I have issues with mine often too. I try to move it from reverse to first and it dont wanna leave the gear it is in. First or reverse. So I bounce it in gear until I get her started moving and then clutch in and pull or push it out of gear. I think she needs oil and she needs to have her gears looked at. But if I am in this condition and she works, I shall check oil and keep going as I am. I am aware of the issue and will keep that in mind. BTW, I put myself in a bad position with it stuck in first gear. I was too close to a trailer moving stuff off it and finally was able to move the trailer (flatbed) out of the way and off I went. Just as I said above, I need to be aware of my situation at all times.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
