Posted by Bob M on February 07, 2014 at 19:12:42 from (69.207.86.40):
In Reply to: 1950 farmall m posted by rustred on February 07, 2014 at 17:25:51:
Usually, but not always!
A buddy of mine has a 47(?) H with what looks like a factory Delco voltage regulator mounted on the generator. However when you remove the cover there's only a single relay (a cutout relay) occupying half of the space underneath - the rest is empty space.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
