Posted by Janicholson on February 09, 2014 at 09:20:46 from (74.60.94.18):
In Reply to: Re: 1950 farmall m posted by rustred on February 08, 2014 at 12:12:42:
Painfuly similar to the VR. Same housing and a Field terminal! A BAT terminal, and a GEN terminal. The Field terminal was used only with battery start and no lights. The terminal connected to the same watt and Ohm resistor that was used on the light switch to provide maintenance charging. The fact that it is there provides no end of discomfort to thse trying to novice their way through a wiring system on an early letter series. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
