Re: Coolant bypass
Posted by Janicholson on December 18, 2013 at 17:35:15 from (74.60.94.18):
In Reply to: Re: Coolant bypass posted by pete 23 on December 17, 2013 at 16:25:10:
Rethinking the issue. If the common connection to the engine side of the T-stat is the block through the big rear hole, and the hose connection on the bottom, the circulating water would still be able to get to the radiator (undesirable in large quantities for warmup) if the hose port was restricted. It would also restrict block flow to even out the warming up coolant. What I suggested prevents coolant from getting to the other side of the T-stat in large quantities, where it is cooled too much and never allows the engine temp to be "normal". The best solution (posted above by another contributor) is to use a stainless steel sheet metal blocking restrictor plate between the halves of the housing limiting the flow to the radiator to 3/8. Respectfully, Jim
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
