Re: Coolant bypass
Posted by pete 23 on December 17, 2013 at 16:25:10 from (74.33.91.156):
In Reply to: Coolant bypass posted by notjustair on December 17, 2013 at 15:17:05:
I would put a plug in it and then you can drill a hole in plug to size you want. Probably start with about a 1/4 inch hole. When you are doing this , take the thermostat housing off. Put a garden hose in the outlet where it connects to radiator. See how much water flows on through. That is most likely the reason your engines does not warm up. You put a lot of water past most of those thermostats because the housing is corroded out inside. You will notice all newer engines that use the tube style thermostat also have a seal in the thermostat housing to allow only the amount of coolant to flow that can go through the bypass hole in thermostat. Some of those holes are also too large and can be soldered shut and then drilled smaller.
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
