Farmall C Front Wheel Slop
Posted by C. Amick on August 08, 2013 at 14:06:11 from (173.224.156.121):
The tractor has a narrow front. There is quite a bit of play between the inner wheel bearing and the hub. I couldn"t see anything wrong with the bearing. I tightened the axle nut as tight as I could against the outside bearing. I guess the hub is worn? I can"t see how the bearing could be worn? Any suggestions for taking up the slack? I guess it will probably last a long time the way it is.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
