Tapered roller bearings cannot be run with "as much as I could" preload. Tyhey will be toast in short order. If loose after tightening, there is a bearing out. Running it will destroy the spindle and thus the lower bolster. Not good!!. Take it apart and find the real issue. It should have preload as follows. With the other tire on a 4X4 to lift the wheel that is loose, replace bearings and seals as needed. Pack the bearings with wheel bearing grease. Assemble. Tighten the spindle nut till the wheel just starts to feel some drag as it is turned by hand. Whack the casting of the wheel with a wooden 2X4 to seat the bearings. Check the spin again if loose retighten the nut till it will only spin on its own about one turn after a good hand spin. Loosen the nut one castle and pin it there. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
