Evan Mellott from Iowa said: (quoted from post at 09:43:56 04/22/13) I want to make a F-20 duckbill front-end for the tractor I'm restoring. I have located a F-30 duckbill front-end.
I've checked out and compared both a F-20 and F-30 duckbill front end, and the part numbers of the top-half of the "bill" and the lower half of the "bill" are the same.
So what my question is, can I take the 2 halves of the "bill" and gears off the F-30 front end and put them on a F-20 steering shaft and bolster, hence creating a F-20 duckbill front-end.
This may be a confusing question, but thanks for any help. I believe its possible....
I think I understand what you are trying to say.
Yes, it is true that both the F30 and F20 'duckbill' steering gear assemblies are the same. But they will only bolt to the bolster made for the 'duckbill' steering. The 'duckbill' steering gear assembly will NOT bolt to the bolster used with the worm gear steering gears.
I agree with Oldiron29, unless your F20 falls within the correct serial number range to be an original 'duckbill' adding the duckbill steering is not going to make it collectable or more valuable, it will just be a F20 with incorrect steering. That said, if you just want to add the 'duckbill' steering because you think it is cool, then that is totally fine. Just don't try to pass it off as a genuine "duckbill" F20.
This post was edited by Nebraska Kirk at 14:50:39 04/22/13.
Today's Featured Article - A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
