Posted by Evan Mellott from Iowa on April 22, 2013 at 08:43:56 from (65.168.252.130):
I want to make a F-20 duckbill front-end for the tractor I'm restoring. I have located a F-30 duckbill front-end. I've checked out and compared both a F-20 and F-30 duckbill front end, and the part numbers of the top-half of the "bill" and the lower half of the "bill" are the same. So what my question is, can I take the 2 halves of the "bill" and gears off the F-30 front end and put them on a F-20 steering shaft and bolster, hence creating a F-20 duckbill front-end.
This may be a confusing question, but thanks for any help. I believe its possible....
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
