Posted by Zachary Hoyt on January 04, 2013 at 08:38:42 from (74.47.58.105):
I was plowing snow again today with the 300 and had been out about 10 minutes when I heard several clunks and stepped on the clutch. I was not able to let up on the clutch without killing the engine. The engine runs normally with the pedal down. The IPTO works normally. When I shut the tractor down and blocked the clutch I was able to push the tractor ahead a few feet with the transmission in neutral and everything was normal. The transmission shifts through all gears normally. I took the cover off the TA clutch and looked in there. With the clutch pedal blocked I could rotate the TA in one direction but the TA clutch disk did not move. With the clutch pedal back I could not rotate the TA by hand in either direction. With the pedal blocked I put the tractor in 1st gear and rocked it back and forth, when the TA flywheel turned one way the clutch disk would turn the other way. I removed the clutch inspection cover and everything looked normal. I am wondering if I have a ramp/rollers problem or some other kind of TA problem and if there is anything I can try short of double splitting the tractor again. I had it apart in the summer and can do it again but of course I would rather not if it could be helped. Any advice will be very much appreciated. Zach
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
