If the transmission input shaft is messed up a double split is needed. If not and you can support things a split at the transmission will let you remove both lower and upper transmission shafts. Yes transmission work not much different than a H. PTO parts and the counter shaft is splined with all gears on it single gears is most of the difference. Unlike a H the counter shaft slides out of the gears to remove.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
