Posted by Zachary Hoyt on December 31, 2012 at 18:50:50 from (173.84.189.49):
In Reply to: Re: Frustration posted by cbice on December 31, 2012 at 18:11:44:
Thank you for the advice, it started pretty well when the temperature was warmer and once the engine has been running I can shut it off and it will start right back up again instantly, but something about cold starting seems to be hard for it. I have not heard of putting your hand over the intake, I imagine that would function rather like a choke plate but maybe better. The rotor does turn with the engine when I checked, I wondered about that too. Zach
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
