Posted by cbice on December 31, 2012 at 18:11:44 from (74.79.227.241):
In Reply to: Frustration posted by Zachary Hoyt on December 31, 2012 at 17:57:44:
Hello zack, I had a 300, and it would not start if you had any throttle on.,also had to hold my hand over carb to get it started. Make sure the dist hasn, cut a pin , the hydrolics put quite abit of pressure on it Clif in ogdensburg 3157134115
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
