Re: Super C Camshaft Gear and Distributor Drive Gear
Posted by El Toro on September 19, 2012 at 04:41:00 from (108.3.143.30):
In Reply to: Re: Super C Camshaft Gear and Distributor Drive Gear posted by Smith1000 on September 19, 2012 at 04:15:51:
You don't need a block under the drawbar unless you're going to pull the engine. You don't need to pull the engine to replace those gears. You may be better off to pull the camshaft and have your local auto machine shop to remove the old gear using their hydraulic press and press the old gear off and the new gear on. The crankshaft gear and damper pulley isn't going to come off easily. Hal
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
