Re: Super C Camshaft Gear and Distributor Drive Gear
Posted by Smith1000 on September 19, 2012 at 04:15:51 from (199.192.211.205):
In Reply to: Super C Camshaft Gear and Distributor Drive Gear posted by Smith1000 on September 18, 2012 at 18:15:04:
The camshaft gear has portions of the teeth missing in the center portion of parts of the gear. The outer edges are okay, which is probably why it is still spinning and still works the pump. There is one part of it where the edge is missing pieces of 2 teeth.
I have several different types of pullers and have a torch for heat.
I"ll support it under the bell housing. Didn"t think about a block under the drawbar. Hopefully, I do not need to pull the engine though.
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
