Mine seems to be stuck all the way around the fly wheel, I've pried from behind the clutch thru the three holes on the outside of the fly wheel and also thru the two holes on the back side of the fly wheel. The new pressure plates don't fit all the way around like this one does. Will heat around the flywheel/starter ring help or is that a bad idea?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
