An M/H clutch has 6 bolts that you have to take out to remove the pressure plate. The three bolts that you put in take up the pressure from the pressure plate so it is easier to reinstall and put the tractor back together.
Sorry no B specific advice, but hopefully you can use some of the info.
Edit - Yeah, there are 6 bolts to take out to take the pressure plate off a B. Everything looks pretty similar to the big tractors. You have to take these out. Look at the parts diagram and you can see what is going on pretty well.
[quote:08eb3ca6bc] 6 179816 BOLT Hex, 5/16"-18 x 3/4", G5, Full Thd, BOLT, Hex, 5/16"-18 x 3/4", G5, Full Thd [/quote:08eb3ca6bc]
This post was edited by sflem849 at 12:37:12 06/10/12.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
