High voltage from a charger will burn them glow plugs out zip. Many different ways to test them but firt you want to determine if you have current available to them. A test light right at the junction block where all the glow plugs are hooked together at the insulator by the nozzles will tell you if you have current to that point. If yes, I think you took them all out. If no light there you have to work your way back to meter , switch etc.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
