Use glow plugs always, even if l00 degrees out. Pre cup engines have to have a outside heat source to ignite fuel until sufficient heat and turbulence is created. It may well start when warmed up , shut down and immediately restarted without using glow plugs but then again five minutes later it most likely won't at least with out missing and fooling around. Do not even think of using ether if you are using glow plugs as it may well blow the whole intake manifold off because at least one intake valve is open all the time. Make sure all six glow plugs work. Hold them for a full minute and keep holding them when starting because they will cool off in 5 seconds. A good pull , even on a worn out engine, should get it running if glow plugs are working. And pull the throttle wide open to start.
Today's Featured Article - A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
