Posted by Andrew Psencik on February 11, 2012 at 14:49:33 from (166.205.8.41):
I have a 560 diesel that smokes when cranking, but won't start. Won't start pulling either. Will kick off on a little bit of ether but just for a second. I don't use it much, just to see if it would even run. Just bought this thing and have no previous info. I pulled out kill cable and tractor still smokes like it's getting fuel. I'm pretty sure pump is bad. How hard are these things to rebuild ? I'm a good mechanic and a machinist by trade. so what I am asking is should I get a rebuilt one, or rebuild my own ? Thanks.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
