Flow under no pressure only really tells you the pump is turning. You need to put it to work, I mean turn steering wheel or even put the pressue gauge in the return line. Like I said before, the relief valve is in pump so you can safely block return.While observeing the flow coming out of return line, turn steering wheel. If front wheels do not turn and flow stays the same that will tell you flow is going right on through bolster valve and cyl. If the flow stops or darn near stops, that tells you it is pump or relief valve. A shot pump will flow almost identical amount of oil with no pressure applied. That is why we flow rate pumps with flow raters and check free flow against flow under pressure. I would sure do more checking on pump part of problem before I got involved with the front bolster.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
