Thanks Pete23, I'm gonna pull the pump and disassemble the check valve and maybe even split the pumps and make sure what's goin on in there. Maybe before I drain everything I'll disconnect the return line again and see how the wheel turns with the line disconnected and also observe the flow rate while I turn it. So, looks like I have some work to do. Could be worse, it could be snowing! Tod.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
